It is currently Wed Jan 18, 2017 4:29 am
PostPosted: Mon Mar 15, 2010 7:02 pm
Hey people, I'm using a Nikon D5000 with the stock 18-55mm lens, I was wondering if i could achieve this sort of image:
i can get a F number of 3.5 to 36 depending on zoom, any ideas?
PostPosted: Mon Mar 15, 2010 7:30 pm
With your current gear, zoom in to 55 mm, stand as close as you can, and set an aperture (in aperture priority) of F/5.6. As far as image settings go: try setting the picture control to vivid with a bit more saturation and contrast, and sharpening to 7. That should do it on the technical side ;)
PostPosted: Mon Mar 15, 2010 7:57 pm
So ,
55mm zoom, Vivid control, then on photoshop/Gimp turn the saturation down and turn up the contrast up , till im happy with it
PostPosted: Mon Mar 15, 2010 8:10 pm
Well, you can customize your picture control in-camera to do the things I said, to match the image as close as possible.
to completely mimick the effect you probably need nikon D3, and an 85 mm F/1.4 (those are the exact things used in the image) ;)
PostPosted: Mon Mar 15, 2010 8:11 pm
How you know that :L ye okay ill try next time i'm out
PostPosted: Sun Mar 28, 2010 9:09 pm
If you want a cheap alternative to the f1.4 85mm, I'd look for a used prime 50mm on ebay, you could probably get a cheap one for like 100$ http://cgi.ebay.com/Nikon-AF-50mm-f-1-8D-Nikkor-Camera-Lens_W0QQitemZ260571385688QQcmdZViewItemQQptZCamera_Lenses?hash=item3cab43cf58 and put it at a low aperture to get similar results. (maybe stand a bit closer then they would have been)
