It is currently Wed Jun 19, 2013 2:41 am
 Post subject: Upgrade
PostPosted: Fri Jan 29, 2010 5:57 pm
Hello everybody ive got a Canon 450D with a EF-S 55-250 F4-5.6 IS which i use mainly for motorsport, my question is would be worthwhile upgrading to the 100-400 F4-5.6 L IS USM to take motorsport pics.
PostPosted: Sat Jan 30, 2010 4:33 pm
If you have the money and you usually use or need that telephoto range,by all means get it.Not only you would have the ability to zoom in closer.also you would have a professional grade lens.Better build quality,image quality,sharpness and less aberrations.
Canon 40D w/vertical grip
Sigma 24-70mm EX DG f2.8
Canon EF 300mm f2.8 L USM
Canon 400mm f5.6 L USM
San Disk Ultra II 4gb
Manfrotto 681B
Canon 200 EG backpack.
PostPosted: Sun Jan 31, 2010 7:11 pm
You could also consider the Sigma 150-500, its quite a bit cheaper, and if your using it when there's enough light i think it could be almost as good.
Do check out if it works with AF on the 450D, though i think it does.
Jake
PostPosted: Sun Jan 31, 2010 7:24 pm
Take a look at the Sigma 120-400mm. It has the same aperture range as the canon you mention. I own that lens and I am very satisfied with the results. The OS is awesome, and it is much cheaper than the canon 100-400mm.
Take a look at it, maybe you'll find it a good option.
Canon 5D Mark II
Canon 24-105mm f/4.0 L
 Post subject: Re: Upgrade
PostPosted: Tue Feb 02, 2010 2:40 am
what i would ask, is "do you need it?"
have a look at what you are currently using, and how it isnt doing the job you want it to.
is the focal range too short? is the image quality too low? is the aperture too small?
a lens like this is going to be VERY expensive, so its worth considering these things before you purchase.
No guts, no glory
Canon 5D mk II, Canon 70-200 f/2.8L USM, Canon 24-105 f/4L IS USM, Canon 50mm f/1.4, Sigma 24-60 f/2.8, canon 430EX II, 2x Yongnuo YN560, Cactus v4 triggers
