It is currently Thu Jun 20, 2013 8:33 am
 Post subject: 2 girls flying
PostPosted: Mon May 11, 2009 12:26 am
I didn't really know where else to put these...
5d
17mm
f10
1/25
iso100
Please let me know what you think!
Velbon Sherpa 200R
PostPosted: Mon May 11, 2009 8:44 am
Hi Paukl,
Love the effect. With an exposure time of 1/25th I'm guessing that you also apply a motion blur filter but I could well be wrong. :? Would you care to share any special problems or tips for taking such a shot?
PostPosted: Mon May 11, 2009 10:25 am
Hi Bob,
The thing they're in is called (i think) a swing caroussell, it spins quite fast. I experimented a bit with the shutter speeds to begin and came out at 1/25 being the best trade-off between motion blur and visibility of the subject. I basically used the same "drag" technique you would use for the kind of shots where you photograph cars and blur the background.
Did that make sense?
Velbon Sherpa 200R
PostPosted: Mon May 11, 2009 10:59 am
Absolutely. :) And nice to know that the effect can be achieved without a lot of post-processing.
PostPosted: Mon May 11, 2009 11:27 am
Nice shot, The effect is quite unusual, if you look at normal 'panning' shots, you will notice the background blur to be nearly parallel to the horizon. But, in this case you can (without much observing eyes) see the blur to be making circular streaks (most probably centered at the focal point).
In theory this is possible by using a very wide angle lens. I think you have been using one. can you please disscus some details (if you like), like Lens and focal length used, subject distance, aprox angle thru which you rotated the camera during the complete shot.
I am very new in this field, it can help me a lot. Thanks.
Regards,
Varun
Canon 1000D : EFS 18-55 IS
Sigma 70-300 APO DG Macro
Canon 50 1.8 II
Pentax SFX
Visit My Flickr
PostPosted: Mon May 11, 2009 9:48 pm
Hey nice capture, the composotion is really good because your subjects are nicely centered. Plus they aren't fully sharp which reinforces the sense of speed. And on top of that I really like how the top of the caroussel has the sky as background and the rest is in front of the green trees.
Where's the "fav" button?
Quentin
Hey, I told you I was going to get my pro account someday!
My blog (in French!)
PostPosted: Mon May 11, 2009 11:19 pm
Thanks for the thumbs up Quentin :)
@varunchauhan: The details of the shot are below the photo, I used my 17-40 lens zoomed all the way out to 17mm so you're right about the ultra-wide part. Judging from the length of the stripes and the fact that at 17mm the lens gives an angle of view of about 90 degrees, I'd say I moved about 4 to 5 degrees during the photo. I really just locked on to them apassing by, and kept following them as the shutter opened. I'm guessing 1/25 might be a sweet spot for fast moving objects though, I'm gonna try and do some more blurred shots at that speed. I think they were about 1,5 meters away from me at the time of shooting, and the centre column of the swing-ride would be about 4 meters away. I've also noticed that some of my other shots, shooting them when they were more to the side of the swing, didn't quite get the feeling of speed at 1/25. I think because you obviously pan a lot less when they are, from my point of view, at the side of the caroussell. Hope this is some use :)
Velbon Sherpa 200R
PostPosted: Tue May 12, 2009 6:35 am
It sure is, thanks a lot.
Although i can't go that wide on my crop frame unless i buy some exotic lens like the sigma 10-20. But i'll try to get a similar effect. I think the key here is the closeness to the subject.
Regards,
Varun
Canon 50 1.8 II
Pentax SFX
Visit My Flickr
PostPosted: Tue May 12, 2009 2:35 pm
go for it! :)
but you can also get the same circular effect, I think, by just turning a good amount of degrees. And to do that at a reasonable shutter speed, you're probably right that closeness to the subject is the key. good luck!
Velbon Sherpa 200R
PostPosted: Tue May 12, 2009 8:32 pm
Very nice shot, i like it, but it makes me feel giddy looking at it :)
canon 400D
18-55 lens
tamron70-300 lens
sigma 18-200 os lens
All my photos are clickable
my flickr
