It is currently Sat May 25, 2013 6:27 am
 Post subject: 50-500mm
PostPosted: Sat Mar 08, 2008 5:44 am
This Friday I am going to a base to photograph a historic event, I am planning to rent a Canon EOS 40D,Sandisk 4GB,and 50-500mm, I just wanted to make sure if the 50-500mm will work on the 40D?
PostPosted: Sat Mar 08, 2008 5:58 am
Kriss, do you mean the Sigma 50-500mm? If so, then yes it should work fine... but remember when this lens is zoomed-in, your autofocus may not be as good as it could be becuase it's slower than f5.6.
PostPosted: Sat Mar 08, 2008 6:43 am
Oh OK cool, I am used to Manual focus.
PostPosted: Sat Mar 08, 2008 7:16 am
It's just a technical note as most DSLRs warn of worse (or problematic) AF performance at f-numbers bigger than f5.6.
As Big Pix on the forum has proven though, the 50-500mm can be a stellar performer!
PostPosted: Sun Mar 09, 2008 12:22 am
Oh, how much does it weigh?
PostPosted: Sun Mar 09, 2008 12:29 am
Have a look at http://www.sigma-imaging-uk.com/lenses/telezoom/50-500mm.htm. :idea:
PostPosted: Wed Mar 26, 2008 6:05 am
does the Sigma 50-500mm have image stabilisation ?
Canon EOS 5D Mark II, EF 24-105mm f/4L IS USM, Domke F-6, Manfrotto 190XPROB w/ 486 RC2 ball head
PostPosted: Wed Mar 26, 2008 9:49 am
Unless its a hidden feature, no. At least it doesnt say so anywhere. Usually Sigma has their image stabilised lenses marked with "OS" (Optical Stabilisation)
Jake
PostPosted: Wed Mar 26, 2008 12:14 pm
Then at 500mm, the slightest wobble will be transmitted in the picture. That won't be very good then
PostPosted: Wed Mar 26, 2008 12:43 pm
How do you rent stuff? and where from? :?
Camera's: Canon 450D - Canon 40D
Lenses: Canon 70-200mm F/4 L, Sigma 10-20mm, Tokina 28-70, Sigma 300mm 2.8, Canon 50mm 1.4, EFS 60mm 2.8 macro
Flashes: 430EXII, 580EX and ST-E2
PostPosted: Wed Mar 26, 2008 2:31 pm
http://borrowlenses.com/
