It is currently Mon Jan 23, 2017 5:14 am
PostPosted: Wed Feb 12, 2014 5:28 pm
Hi all, I need your help, I've been into photography for nearly 3 years now and collected a few lenses and bits and bobs etc etc.
I now have a Canon EF 100-400mm 4.5-5.6 L series IS lens.
So my question is, will a Canon EF 1.4x or a 2x Extender work with this lens, I've googled and You tubed till I'm blue in the face but I can't understand the terminology as I'm still fairly new to photography and only get out with the camera a few times a year..
I've heard the auto focus won't work and I'll lose a few F/stops but I don't understand the F/stop bit.
I wanted to use the extender with the 400mm lens at Airshows this year but I also like my wildlife..
So could someone PLEASE help me out and tell me yes or no whether these extenders (which one if any) will work with my lens, and any pro's and cons, its doing my head in as I can't get a straight answer.
Ps I have a cropped sensor Canon 550D if that helps ??
Chris
Entry Level Canon 550D
EF-S 18-55mm Kit Lens
EF-S 55-250mm Lens
Manfrotto 290 Tripod
Nd Filters 2, 4, 8
UV Filter
Polariser
PostPosted: Wed Feb 12, 2014 6:26 pm
Your 100-400mm L will still work with the extenders but you will lose your autofocus as you read. You tend to lose AF with the extender when the maximum f/stop is 5.6 or smaller with the extender reducing the aperture even further, it looks less than likely that you'll keep AF.
Those extenders work best on f/2.8 lenses as you'd stop down to a maximum of f/4 and f/5.6 with the 1.4 and 2.0x extenders respectively and maintain your AF. However you could still use the 1.4x extender on an f/4 lens and keep the AF.
With the extenders, you will lose some image quality but if you've got good glass in front of it, you may not even notice.
CSC: Canon EOS M3
PostPosted: Fri Feb 14, 2014 3:18 am
I have got a 1.4 Kenko converter and it works on the 70-300L , it should also work on the 100-400L, don`t see any reason why it wouldn`t. But if my experience on the 70-300L is anything to go by I wouldn`t bother using it, auto focus will be much smaller and image quality drops of. Be better to just use the 100-400L and focusing on getting the best possible pictures with that alone.
