It is currently Mon Jan 16, 2017 10:26 pm
 Post subject: Best Lens for landscape
PostPosted: Sun Jan 12, 2014 10:10 pm
I am going on a cruise in April and will visit the Mayan Ruins in Belize. I am looking for the best lens for taking photo's of the ruins from both near and far. I have a Canon XSi and am a newbie for the most part. I currently have a Canon EFS 55-250mm 1:4-5.6 and a Canon 50mm 1:1.8
The issue I often have is not being far away enough to take such photos. I need to be able to get the entire image in from close up.
Any suggestions and recommendations are appreciated!
Thanks!
PostPosted: Mon Jan 13, 2014 2:23 am
You might want to read the "WIDE ANGLE LENS FOR CANON 700D" thread (pardon the caps, I'm just quoting, not yelling.) But short answer: Canon 10-22mm or Tokina 11-16mm (make sure to get the EF-S Canon version, not the Nikon version).
PostPosted: Thu Jan 16, 2014 3:21 am
I started with the XS1 and used primarily the 17-85mm IS lens.
They are easy to find inexpensively and work great as a walk around option.
Canon XSI/450D, 17 x 85mm by jimmy_racoon, on Flickr
takes a pretty wide angle, even on a crop frame XSi:
Sedona Showers by jimmy_racoon, on Flickr
the other option might be the 17-40 f/4L
Seppmann Mill 1846 by jimmy_racoon, on Flickr
best of luck
Canon 5D2 | BG-E6 Battery Grip | Canon XSi/450D | BG-E5 Battery Grip | Canon EF 17-40 f/4L | Canon EF-S 17-85mm f/4-5.6 IS | Canon EF 50mm f/1.8 II | Canon EF 70-200 f/4L IS | Manfrotto 055XPROB | Manfrotto 488RC2
Flickr <--Comments/Favorites welcomed
PostPosted: Tue Jan 21, 2014 9:19 am
If you have enough money, I'd recommend a Canon EF-S 15-85mm, which is wider than the 17-85mm and which has a better optical quality. Still you might want to look at an ultra wide angle lens like the Canon EF-S 10-22mm, the Sigma 8-16mm or the Sigma 12-24mm. This way you have to change your lenses if you want anything with a higher reach but if you are close to your subject these lenses can be pretty awesome.
