It is currently Thu Jan 19, 2017 2:41 am
PostPosted: Tue Jul 30, 2013 11:41 am
if i buy the IXUS 255 is a best camera ? nice photos and videos?
and some questions about this nice camera:
1) what is the problem to have the FullHD video “only” at 24 ft/s ?
is a big prolem or ?
2) there is a solution to eliminate the “limit” at ONLY 10 minutes
of record an movie ? if yes in how mode ?
I see in this site:
http://chdk.wikia.com/wiki/CHDK
no solution in this web site ?
sorry for my bad english, thanks for help me….
PostPosted: Tue Jul 30, 2013 11:01 pm
1) Whether the 24fps frame rate is a problem or not depends on your expectations of how you want to shoot video and play it back. ~24fps is arguably the de facto frame rate you'd find at cinemas or on TV so you have that film-like feel when playing back the videos so if you just want to record basic video and do little to no editing, 24fps should be OK for you. I don't know the camera's ins and outs but I would guess that if you want to shoot at a higher frame rate (either for more life-like movement or for smooth slow motion playback), you would probably have to reduce your video resolution.
2) The 10 minute limit is probably imposed by the compression and the file system of the memory card as opposed to a problem you can just easily "eliminate". You can probably record for longer at a lower resolution.
CSC: Canon EOS M3
PostPosted: Sat Aug 03, 2013 12:29 pm
ok...is more best this ixus 255 or the old ixus 510 ?
PostPosted: Wed Aug 07, 2013 6:32 pm
Personally I would go for the 255 because of battery life, Plus the lens is slightly wider angle being 24mm over 28mm.
Cameras: Canon Ixus 100is. 60D 17-85mm
Computer: 2008 Apple Macbook Aluminum (dreaming of a new retina macbook pro!!)
Phones: iPhone 1g And HTC Wildfire Apple iPad 3 wifi
http://www.flickr.com/photos/gareththomasjones/
