It is currently Mon Jan 23, 2017 7:34 pm
PostPosted: Fri Feb 13, 2015 3:44 pm
Hi,
This is for a live event and i wanted to connect the 500d (or the 550d since i have both) thru HDMI to a projector. But i want my laptop hdmi also to be connected to the projector and use a switcher.
I used a 10mtr HDMI cable and ran it from the cam to the HDMI switcher. Then ran another 10mtr HDMI cable from the HDMI switcher to the projector. In the second input option of the HDMI switcher i used just a 1mtr HDMI cable connected to my laptop. Now when i press the switch on the HDMI switcher it changes to my laptop port. Another port and it switches to the cam. But this is where things get wacky. The cam is not sensed at times. I have to power down the cam a few times and back and then it gets recognized. I cant do this during a live event. So i need some help. Where do you think the problem might be ? In the switcher or the cam ? Or the HDMI cable is too long ? Have any of you interfaced a 10 mtr length wire with a canon DSLR for live view ?
Thanks
PostPosted: Sun Feb 15, 2015 6:17 am
Nobody ?
PostPosted: Sun Feb 15, 2015 2:16 pm
Without knowing the brand and model of switcher, I'm not sure anybody can give a conclusive answer short of making a lucky guess. Personally, I think you're best of consulting a tech support forum.
That being said, 10m is very long for an HDMI cable and while I don't shoehorn Canon's products into neat little boxes, I don't imagine broadcast and long cable configurations were in mind for the 500D/550D. Have you tried using a shorter cable, no more than two metres long?
CSC: Canon EOS M3
PostPosted: Mon Feb 16, 2015 3:54 pm
2 meters i havent tried. I can try and tell you. But even then it wont be practical for me. At an event distance is everything. I cant have a console operator managing audio and projection and get the event presenter on stage to some and stand right next to the sound booth so he can fit on the camera frame. This is what is putting me in trouble otherwise i would have also opted only for the shortest path coming from a stage sound & lighting background. Would one of those miniature line boosters help ?
PostPosted: Mon Feb 16, 2015 11:37 pm
In theory an HDMI repeater/booster could solve the problem but you may need to power the repeater to get the most out of it since the source isn't mains powered.
I didn't suggest a two-metre cable as a permanent solution, I suggested it to establish if the cable length may be the cause of the problem.
CSC: Canon EOS M3
