It is currently Sun Jan 22, 2017 2:53 pm
Canon 70-200mm F4 (non is) vs the 70-300mm f4-5.6 (Non L)
Canon 70-200mm F4 (non IS) 20%  20%  [ 1 ]
Canon 70-300mm F4-5.6 IS 20%  20%  [ 1 ]
Canon 70-200mm F4 IS 40%  40%  [ 2 ]
None of the Above!! 20%  20%  [ 1 ]
Total votes : 5
PostPosted: Thu Apr 18, 2013 7:18 pm
Ok it has been about 8 months since I brought my Canon 60D and 17-85mm lens. I have finally got round to the point where I am nearly ready to buy a new lens, I have been in Scotland for the last few weeks taking landscape shots, these can be seen on my flickr if anyone is interested www.flickr.com/gareththomasjones . My big decision is that I dont want to spend a huge amount of money on a Lens that im not going to use all the time, for example a 10-22 wouldn't really be what I want because I think that that would be too wide and then I wouldnt use that enough.
My real decision is between the Canon 70-200mm F4 (non is) and the Canon 70-300mm f4-5.6 (non L) Now my big question is do I need image stabilisation for out door photos of seals or deer? And would you say the difference between 200-300mm is worth it.
I can probably get the 70-200mm for about £40 more than the 70-300mm which is neither here nor there. I was thinking the Non IS rather than the IS version because I could then maybe afford another lens, the 28mm 1.8 or the 50mm 1.4? Or a speed light If I wanted to use the 70-200mm in doors, this would also be able to be used with my 17-85mm lens.
Also I assume the 70-200mm can be used with the 1.4 converter and still have AF.
Bit of a long post but Hey!!!
Cameras: Canon Ixus 100is. 60D 17-85mm
Computer: 2008 Apple Macbook Aluminum (dreaming of a new retina macbook pro!!)
Phones: iPhone 1g And HTC Wildfire Apple iPad 3 wifi
http://www.flickr.com/photos/gareththomasjones/
PostPosted: Thu Apr 18, 2013 8:23 pm
I've used the 70-200 f4 non IS with a 7D and it's a stellar lens. Just wow. Mechanically and optically.
I think the centre point of the 60D should be sensitive down to 5.6, so the f4 lens with a 1.4TC should still be able to autofocus.
With the money you save buying the non IS, you could also get a tripod :) I'm no expert on canon primes, don't know anything about the 28mm 1.8, but I've heard that the canon 50mm 1.4 is not the best and that the sigma is a better alternative. The Canon 50mm 1.8 (plastic fantastic) is a very good lens optically if you can live with the worst autofocus, it hunts and misses all the time, it's really frustrating.
Good luck making your decision :D there is never a right answer, unless you are a millionaire and just buy everything :D
PostPosted: Thu Apr 18, 2013 10:06 pm
The old 70-300 isn't particularly great, and if you were to look for that range zoom the latest Tamron equivalent is supposed to be a good one.
Question then is, what do you think you'll use the lens for? If you think you'll regularly need 300mm, get a 300mm zoom. Yes, the 200mm can take a 1.4x to give up to 280mm f/5.6 with AF, but the extender is extra cost and it never is fun adding and removing it if you need to shift ranges in a hurry.
For animals, it does depend a lot on how close you can get to them. IS is a nice to have but not essential.
PostPosted: Thu Apr 18, 2013 10:18 pm
I was in scotland last week and took this https://www.dropbox.com/s/fuuywgklssguimt/IMG_1058.jpg with my canon 17-85mm lens at 85mm. So I was pretty close I would say, I have tried cropping but I loose quality obviously. The outlines on the photo in theory represent the different focal lengths assuming my calculations were correct. Now, will the extra sharpness of the 70-200mm be enough to crop in that little bit to the canon 70-300mm?
I am also quite keen for everything to be Canon brand, partly because im a bit of a brand nut, partly because I feel that they will be better quality but mainly because other brands zoom rings turn the other way and that annoyed me on my old film cameras!!
PostPosted: Fri Apr 19, 2013 5:15 am
If you want to shoot wildlife the canon 100-400mm L 4.5-5.6 IS US is also worth taking a look at. It's about 1400€ new but I've seen them used as low as 900€, which is what the 70-200 f4 IS would cost new.
PostPosted: Fri Apr 19, 2013 7:07 am
The backwards zoom is annoying for me too!
On the cropped 70-200 vs 70-300 it is hard to say. The latter is not bad but not great either, whereas the 70-200 is supposed to be quite good all round.
One other option to consider springs to mind: the EF-S 55-250! Cheap but has a reputation for a decent image quality even if the build is nothing to write home about.
PostPosted: Tue Apr 23, 2013 5:25 am
2 things, First look at the Tamron 70-300 over Canon's non -L 70-300. It has a few advantages over Canon's most important to me is a non-rotating front element that makes it much easier working with polarizers. Second, if animals are a big thing you shoot, I will tell you that you will want the longer focal lengths more often than not. Lastly (oops that's 3 things), all though I haven't yet had the opportunity to come and visit my homeland of Scotland (and I do plan on it) I understand the weather can be very yucky which means a lack of light so the IS will come in handy if you need to stretch your shutter speed a bit for lack of light. My 3-cents :)
I've been using the 55-250 exclusively for the past 4 months and will be locked into it for another 5, it's all I have here in Afghanistan. Surprisingly it is a good lens. I've gotten some super sharp images at 55 to 100, I will say though at 250 it is soft.
Mike "The Squirrel"
PostPosted: Tue Apr 23, 2013 6:57 am
I think your over estimating how dark it is up there!! I was able to get 320ths of a second up there at iso 100 nearly every day, so i assume that that speed would be enough to avoid camera shake at 200mm?
As I have said before I am a bit of a brand freak! Canon and Apple all the way! I also want an L lens so I think I have decided to go with the 70-200mm non IS, (unless someone offers me a really good argument against it! or I win the lottery within the next year!!)
Thanks Guys!
