It is currently Thu Jun 20, 2013 6:31 am
PostPosted: Sat Jan 05, 2013 3:31 pm
I have an SX30.... it use NB-7L...... about $24-36 off ebay....
http://www.ebay.com/itm/Canon-NB-7L-Li- ... 20ce73ac6b
but there are generic knock-off no name ones, 2 pack for $10.......
http://www.ebay.com/itm/2-x-Battery-Pac ... 27c893f2da
any worry using the knock-offs?
PostPosted: Sat Jan 05, 2013 4:06 pm
Im using knock-offs since I use batteries! No problems with knock-offs, be prepared they might be less good than the originals. But this may not be a big problem, as you can buy some knock-offs against one original. Two knock-offs give you way more juice than an original.
PostPosted: Sun Jan 06, 2013 8:14 am
I generally avoid the cheapest batteries, but I have not had an issue with third party batteries.
Canon 5DIII, Rebel XTi/400D
Sigma 150mm F2.8 EX Macro
Canon 430EX II
PostPosted: Mon Jan 07, 2013 1:14 pm
thanks
