It is currently Sat May 25, 2013 11:13 pm
 Post subject: Canon 24-105 F4L Lens
PostPosted: Fri Dec 21, 2012 9:41 am
Dear All
I need a suggestion here , by looking at the subject you would have realized that i am inclined towards this lens..
Yes , but i want to know if this lens is good for wedding / indoor photography.. With F4 , will it fell short ? I have a canon 5d mk3 body , so my assumption is boosting up ISO might get away with low light scenarios , but in practical how good is this lens? I am also thinking of 85mm 1.8 for wedding , being prime , i heard this lens is good for portraits and candid shots , but i'll have to sacrifice the zoom range offered by 24-105 , is it worth ? Coz 85mm 1.8 is less expensive compared to 24-105 and does it make sense in the first place? Pls advise me on this.
Mano
Canon EOS 5D mk III|Canon EOS 7D | 70-200 F2.8 L IS II USM | 400 F5.6 L USM
PostPosted: Fri Dec 21, 2012 11:45 pm
If you're shooting an f/4 lens indoors, you're going to be using flash (and hopefully bouncing it).
I shoot all-primes at weddings, 35/1.4, 50/1.8, 85/1.8, and 135/2 and I *still* need flash if I want to keep a reasonable ISO. Weddings are specialized situations, so I'd suggest specialized lenses. 24-105 is non-specialized, so I don't really recommend it.
PostPosted: Sat Dec 22, 2012 10:42 am
Hi Plymer
I have 5dmk3 even then i have to use flash??? Coz ISO shudnt be an issue in my opinion.. But pls correct me if i am wrong as i am not a pro and just wanted to try out with my brother in law wedding..
Regds
Mano
PostPosted: Sat Dec 22, 2012 3:29 pm
I'm guessing using flash gets your exposure times to 1/200th or less with a fairly low ISO, resulting in less blur and noise.
PostPosted: Sun Dec 23, 2012 11:10 pm
No flash at ceremonies, ISO under 2500 and shutters ~1/80th, apertures to suit.
For receptions, my go-to is ISO 1250, f/3.5, 1/60th, and 1/4 power bounced up or slightly backward. Every venue is different but most places I shoot indoors at work right around this for a nice mix of ambient and flash. Change apertures/flash power/ISO to suit.
PostPosted: Tue Jan 15, 2013 5:06 am
I know this is an old thread but here is my 2 cents.
I have the 24-105 and it is not very good for indoor, non-flash photography. I have had a lot of luck with my EF 50 F/1.4 indoors with no flash. It is an inexpensive (relatively) lens that performs wonderfully. The only down side is that you actually have to use your legs to zoom. :wink:
Canon 5D Mk II * 17-40 F/4L * 24-105 F/4L * EF 70-200mm f/4L IS * Tamron 28-75 f/2.8 * EF 50 f/1.4 * Lensbaby Composer * EF 100-400 L * EF 100 F/2.8 Macro * EF 1.4x Extender III * Speedlite 430EX II * Speedlight MR-14EX *
