It is currently Sun May 19, 2013 12:54 am
PostPosted: Wed May 16, 2012 7:53 am
Hello guys,
Id like to know if you connect a 500d thru its mini hdmi out (using a standard hdmi cable with a mini to standard hdmi adapter on the cable end that plugs into the cam), how does it work ?
Has anyone tried this, and if yes does the video play out in full hd on the lcd screen or in a small windowed format.
Whats the correct way to relay the full HD signal to a large screen. This is for a live event where i need to show a performers face upclose on a large screen. I dont need the cam to be recording during this action.
Thanks
PostPosted: Wed May 16, 2012 1:43 pm
The HDMI sockets usually mirror whatever is on the screen, so that is exactly what you see on the screen if you were using it usually. I haven't actually tried it yet, there is only one HD screen in the building at the moment.
Canon EOS 500D
