It is currently Mon Jan 23, 2017 12:51 pm
PostPosted: Fri Apr 20, 2012 10:52 am
Does LH DC60 Lens Hood for SX40 HS require filter adapter ? Or it works straight out of the box. Also please help me to buy this online ship to India.
PostPosted: Fri Apr 20, 2012 11:13 am
The lens hoods have a bayonet mount so you don't need a filter adapter.
As far as I know you can't use the lens hood when a filter adapter is mounted. I think it uses the lens hood bayonet.
But if you buy the SX-40 the lens hood should be in the box...?
