It is currently Thu May 23, 2013 1:57 am
PostPosted: Fri Apr 06, 2012 7:51 am
I dont know if my point is valid or not but to me the 24-105mmL lens used for the review is way sub standard compared to 24-70mmL. I have had used this and sold it out. It would be great if the test of both camera use the same type of lens (24-70mm f2.8L) or nikon 24-70mm on both cam (adapter on Canon cam of course).
I dont expect Canon will do better in sharpness than Nikon, all these while I noted the canon images slight softer but responded well in PP for sharpness. This at least a better head to head comparison...IMHO :)
chin up, cheer up...
EOS5DMKIII/ Canon 50mm f1.8/ Canon 24-70mm f2.8 L USM/ Canon 100mm f2.8L IS Macro usm/ Canon 70-200mm f2.8 L IS USM II / Manfrotto 055PROB(488RC2)/580EXII Flash
PostPosted: Fri Apr 06, 2012 11:52 am
To Gordon.
I had gone through ur last comparison as always. I have 1 question?
What will the results If we compare 100% crop of 5DIII and same portion from D800 ( no Degrading MPs- same frame as its matches the canon version---i hope every body understand what i am trying to say), i know we r doing in-justice as we comparing 100% crop of Canon 5DIII vs (say ) 70% crop size of nikon D800. But if u r a common man and only going to see the results, i think in this case we dont need to worred about if its 100% or .. what so ever
Can u tell me in that case what will be the results
Is D 800 will out perform Mark3 at High ISOs
just little curious!!!!!!
Nikon D800
Nikon AFS 50mm F1.8 G
Sigma APO 70-200 F2.8 EX DG OS HSM
Sony H50
PostPosted: Sun Apr 08, 2012 2:36 am
How do you figure? :shock: Only if you need f2.8. The 24-105 is sharper than the 24-70, DigitalRev proved it.
But I agree the comparison might be better with equivalent lenses.
PostPosted: Tue Apr 10, 2012 1:29 pm
http://www.photozone.de/canon_eos_ff/42 ... 5d?start=1
http://www.photozone.de/canon_eos_ff/52 ... ff?start=1
you can look at this mtf chart....but using same type of lens is much fair comparison...
