It is currently Wed Jun 19, 2013 12:00 pm
PostPosted: Tue Mar 06, 2012 7:31 am
Hi - I shoot recipe books and also cafe shots but having difficulty with low light getting lots of noise. My Strobe light shots are fine doing food with 60mm macro - but anything else is just not quite as sharp.
Usually using EFS 15-85 lens with 550d (T2i).
Will upgrading to the 7D improve my shot quality significantly? Both appear to have similar image sensor. Or should I just suck it up and improve my skills with lighting.
Any help appreciated.
PostPosted: Tue Mar 06, 2012 8:21 am
They have near enough the same sensor so it isn't going to change the output. Best look elsewhere to make a difference.
PostPosted: Tue Mar 06, 2012 12:09 pm
I do have the 500D / T1i and thought of upgrading to the 7D but decided not to do so as the difference is close to not existing. I bought some nice lenses instead (especially Canon EF 100mm 2.8L Macro IS USM and Canon EF 100-400mm 4.5-5.6L IS USM) which actually DID improve the image quality and they can be used on later cameras as well. I only buy full frame lenses as I'm going to get the 5D3 in the future, which also does improve image quality.
Again: The 7D has much better ergonomics than the T2i, and it's faster, has a bigger viewfinder etc. - but as the image quality isn't really better, I decided to skip it.
PostPosted: Tue Mar 06, 2012 7:27 pm
Like the other guys have said, the cost/benefit will arguably not be worth it if low light performance is your main motivation for upgrading to the 7D. An upgrade to your lens will make a more apparent difference - a constant f/2.8 or faster lens will let in significantly more light at a given shutter speed while you can keep the ISO down as well, reducing the likelihood of noisy images.
Full-frame is also an option but it will rule you out of using the 15-85mm lens.
PostPosted: Tue Mar 06, 2012 11:23 pm
I recently played around taking food shots and used the 7D, we had made sushi and it looked terrific on the plate. I used the 15-85 at wide angle, when at 3.5 and f4 aperture and with IS made more than sufficient difference that its a better choice than a prime without IS. Not like the food was running away. :)
When I used the 85 1.8 and 50 1.8 with aperture of around 2 to 2.8 (handheld), to keep up shutterspeed, the shallow depth of field was definitely tricky. Wide open the 50 is soft.
When taking photos in a cave recently I started with the 15-85 and changed to the 50 prime, but in hindsight would have had more consistent results with the 15-85 and its IS
I guess in low light it really requires a tripod, live focus and carefully placing your subject and framing it carefully.
As I don`t have a tripod and was getting hungry, priorities took over.
I don`t think its the 550D or the 15-85 that is the limit, its plenty sharp, there maybe small incremental improvements in upgrading lenses and body, but may I suggest that most of your improvements will come from improving your lighting. For artistic value the 85 1.8 would be a good addition if you don`t already have it.
