It is currently Sat Jan 21, 2017 8:38 am
 Post subject: Canon FD lenses
PostPosted: Wed Mar 14, 2012 12:00 pm
Anyone have any experience with FD lenses on EOS Digital body (with FD->EF adapter)?
Would like to have a 400mm prime one day, cheapest one Canon offers is 400mm f/5.6L for $1.2k. But I've realized that there are some FD 400mm lenses that are significantly cheaper (~$300 price range). Granted, I know that the lens will be fully manual, but will be worth it in order to have some great telephoto reach.
Thoughts? Words of caution with FD->EF adapter?
MrKman | website
Canon EOS 5D II + PowerShot G12
Samyang 14 f/2.8 + Tamron 28-75 f/2.8 + Samyang 35 f/1.4 + Sigma 70-200 f/2.8
Yungnuo YN560 + YN560ii (x2) + Cactus V4
WISHLIST: 300 f/2.8
FORMER: Canon 5D + 40D + 450D + 18-55mm + 28-135mm + 50 f/1.4 + 100 f/2.0
 Post subject: Re: Canon FD lenses
PostPosted: Wed Mar 14, 2012 12:26 pm
I do have an FD-EF adapter and it increases the focal length by 1.25x and the light coming through is getting less about 2/3 of a stop. A 400mm F5.6 lens gets a 500mm F7.1 lens for example. With a 1.6x crop sensor you get "800mm" F7.1. But it works in Av-Mode, especially in bright day light and focusing is OK in live view (+magnification). Still the image quality is slightly worse.
PostPosted: Wed Mar 14, 2012 2:25 pm
You can buy special FD-EF adapter meant for use on such lenses. They are very slim, but often a bit expensive.
Expensive:
http://www.ebay.com/itm/EdMika-0-5mm-FD ... 2a19c5467e
Cheaper:
http://www.ebay.com/itm/CANON-FD-EF-ult ... 0639196400
PostPosted: Wed Mar 14, 2012 2:31 pm
Those are to be outfitted on one lens, not interchangeable liek the one Jiko has?
Also, I'm a bit confused on focusing. How do these standard and "slim" adapters affect focusing?
MrKman | website
WISHLIST: 300 f/2.8
PostPosted: Wed Mar 14, 2012 2:58 pm
They are interchangeable, at least as far as I can fathom from the information :S
It's rather more how they don't affect focusing, or at least try to. The slimmer the adapter is, the less problems you will get since you are closer to the original register distance. It's not entirely without issues, but much better than their fatter counterparts.
PostPosted: Wed Mar 14, 2012 5:09 pm
Lorride, what sort of problems can arise? I keep reading about "infinity focus" ...
Just want to know what sort of limitations I'd be dealing with if I choose to go thru with this.
MrKman | website
WISHLIST: 300 f/2.8
PostPosted: Wed Mar 14, 2012 5:27 pm
Due to the differences in mount distance, and adapter thickness, you get an extension tube effect which may mean you lose infinity focus. However, with longer focal length lenses, extension has a much smaller impact than on shorter focal length lenses. If the telephoto can go "past infinity" that may be enough to allow infinity focus.
The other option is some adapters use an optical element to work around the extension effect, which gives them a teleconverter behaviour.
PostPosted: Wed Mar 14, 2012 5:31 pm
interesting! I presume this shouldn't be an issue on FF sensors?
MrKman | website
WISHLIST: 300 f/2.8
PostPosted: Wed Mar 14, 2012 5:50 pm
Sensor size is irrelevant to the mount distance effects.
