It is currently Sat May 25, 2013 10:15 pm
PostPosted: Thu Nov 03, 2011 10:34 pm
Hi everyone, Canon's Hollywood announcement today was, as most expected, a new professional camcorder / movie camera, along with a selection of new lenses and a hint at what might be the EOS 5D Mark III...
But first, here's the new EOS C300 PL with the equally new 85mm PL-mount lens. Note the huge travel on the lens for focusing - necessary for very precise adjustments - and also the gearing around the focusing ring for follow-focus attachments. Full press release below the photos...
A Star Is Born: Canon Launches New Digital Cinema Camera For High-Resolution Motion Picture Production
HOLLYWOOD, California, November 3, 2011/TOKYO, November 4, 2011 – Canon Inc. and Canon U.S.A., Inc. today raised the curtain on an all-new interchangeable-lens digital cinema camera that combines exceptional imaging performance with outstanding mobility and expandability to meet the demanding production needs of today's motion picture industry. The camera, which features a newly developed Super 35 mm-equivalent approximately 8.29-megapixel CMOS sensor, will be available in two models: the EOS C300 Digital Cinema Camera*, equipped with an EF lens mount for compatibility with Canon's current diverse lineup of interchangeable EF lenses for EOS single-lens reflex (SLR) cameras and new EF Cinema Lens lineup; and the EOS C300 PL Digital Cinema Camera*, with a PL lens mount for use with industry-standard PL lenses.
The introduction of the EOS C300/C300 PL coincides with the launch of the Cinema EOS System, marking Canon's full-fledged entry into the digital high-resolution production industry. The new professional digital cinematography system spans the lens, digital cinema camera and digital SLR camera product categories.
Star-Studded Supporting Cast
Equipped with an EF lens mount, the EOS C300 is supported by an all-star cast of high-performance EF lenses, not only the wide array of interchangeable EF lenses for EOS SLR cameras that have earned the trust and respect of photographers around the world, but also the EF cinema lenses in the newly announced Cinema EOS System. When outfitted with a Canon EF lens, the C300's peripheral illumination correction automatically corrects for vignetting in accordance with each lens's optical characteristics, and enables iris control from the camera. Canon EF lenses also enable the recording of such metadata as the name of the lens used, aperture setting and shutter speed.i
Show-Stopping High-Resolution Full-HD Performance
The Canon EOS C300/C300 PL's newly developed Super 35 mm-equivalent CMOS sensor incorporates approximately 8.29 million effective pixels and has a pixel size that is larger than that for conventional professional camcorders, enabling greater light-gathering capabilities for enhanced sensitivity and reduced noise. The sensor reads Full HD (1920 x 1080 pixels) video signals for each of the three RGB primary colors, decreasing the incidence of moiré while realizing high resolution with 1,000 horizontal TV lines.
Supported by a heightened signal read-out speed, the CMOS sensor reduces rolling shutter skews, a phenomenon prevalent with CMOS sensors in which fast-moving subjects may appear diagonally distorted. Additionally, the powerful combination of the sensor with Canon's high-performance DIGIC DV III image processor facilitates high-precision gamma processing and smooth gradation expression.
In addition to MPEG-2 Full HD (MPEG2 422@HL compliant) compression, the EOS C300/C300 PL employs 4:2:2 color sampling for high-resolution performance that minimizes the appearance of "jaggies" at chroma edges. Additionally, with a maximum recording rate of 50 Mbps, the camera supports the recording of high-quality video.
The camera's video and audio recording file format adopts the industry-standard MXF (Material eXchange Format), an open source file format ideally suited for non-linear editing systems. Recording to versatile, readily available CF cards, the EOS C300/C300 PL realizes high cost-performance and, equipped with two CF card slots, makes possible the simultaneous recording of video data to two CF cards.
Ready for Action
With a compact body design measuring 5.2 (w) x 7.0 (h) x 6.7 (d) inches, the Canon EOS C300/C300 PL delivers exceptional maneuverability, enabling shooting from vantage points all but inaccessible to large cinema cameras, such as close to the ground for high-impact low-angle shots, and alongside walls. In accordance with on-location shooting needs, the camera can be outfitted with a handle, grip, thumb rest and monitor unit, and offers an array of industry-standard terminals, including HD/SD-SDI video output for the external recording of high-quality video content. When using a WFT-E6B wireless file transmitter for EOS digital SLR cameras (sold separately), the EOS C300/C300 PL can be controlled remotely by means of such common devices as smartphones or tablet PCs.
The camera is equipped with four start/stop buttons positioned at various locations to satisfy any preferred camera-holding style, and can be outfitted with a variety of third-party accessories, including matte boxes, follow focuses and external video and audio recorders. The unit also achieves seamless integration with third-party editing systems and provides added peace of mind through its dust-proof, drip-proof construction and built-in cooling system.
The new camera allows users to adjust image quality to match that of professional camcorders and EOS-series digital SLR cameras, and offers Canon Log Gamma, enabling flat image quality with subdued contrast and sharpness for maximum freedom in post-production editing and processing. In addition to frame rates of 59.41i, 50.00i, 29.97P, 25.00P and 23.98P, the EOS C300/C300 PL features a 24.00p mode, matching the 24 frame-per-second frame rate of film cameras for high compatibility with common film-production workflows.
Other features include fast-motion shooting, achieved by capturing fewer frames per second to create action up to 60x normal speed, and slow-motion down to 1/2.5xii made possible by capturing more frames per second. Frame rates between 1 and 60 frames per second (fps)iii can be adjusted in increments of 1 fps. Additionally, a selection of Custom Pictures lets users freely adjust image quality for greater control over how content looks.
Pricing and availability
The Canon EOS C300 (EF mount) digital cinema camera is scheduled to be available in late January 2012 for an estimated list price of $20,000. The Canon EOS C300 PL (PL mount) digital cinema camera is scheduled to be available in late March 2012 for an estimated list price of $20,000.
For more information and to view online demonstration footage of the new products please visit: www.canoncinemaeos.com
Last edited by Gordon Laing on Sun Nov 13, 2011 10:43 pm, edited 3 times in total.
PostPosted: Thu Nov 03, 2011 10:36 pm
New EOS mount camera... a video camera! Event it going on right now so still waiting for details. Looks like an all out cinematic video camera with lenses to match.
Best coverage I've seen so far at engadget:
http://www.engadget.com/2011/11/03/the- ... -liveblog/
PostPosted: Thu Nov 03, 2011 10:57 pm
Can't find an official press release yet, but following site seems to have a lot of info:
http://www.dvinfo.net/article/acquisiti ... meras.html
Super35 size is slightly bigger than APS-C if I'm reading it right. 8.3MP sensor but the system only outputs 1080p video.
PostPosted: Thu Nov 03, 2011 11:47 pm
I didn't "get it" at first but maybe I'm beginning to understand. Canon now has the following pages describing the "Cinema EOS" system:
There is also a "Canon Cinema EOS" microsite here. A superb video on that! But at $20,000 for the body (source) this isn't exactly your family holiday video camera! That's twice the price of the Red Scarlet which also takes EF lenses.
PostPosted: Fri Nov 04, 2011 3:41 am
Agree that the body price seems high, but the lenses look like a focus puller's dream!
Definitely a must (rent, tho) - Mark
PostPosted: Sat Nov 05, 2011 1:22 pm
Bob Andersson wrote:
A superb video on that! But at $20,000 for the body this isn't exactly your family holiday video camera! That's twice the price of the which also takes EF lenses.
The C300 seems like a more complete package than just the Red Scarlett brain.
I am looking forward to seeing Zacuto doing a test of this camera compared to the usual line up, which I am sure they will.
Maestro:
Those Canon PL mount lenses are nothing different than what other companies have been making for years ;)
PostPosted: Fri Dec 09, 2011 2:38 pm
Found this good video highlighting some of the features of of the C300
http://vimeo.com/32067654
