It is currently Thu May 23, 2013 9:18 am
PostPosted: Thu Nov 29, 2007 11:41 pm
I was just browsing Canon 's The EF Lens World Catalogue, single focal length lenses, and came across a reference to a drop-in filter.
As far as I can tell, it seems to be a filter for those lenses whose front element is too wide for a conventional filter. For example, the Canon EF 400mm f/2.8L IS USM has a front element of about 160mm in diameter.
But what exactly is a drop in filter? Could it be that it's placed on the rear element, much as a tele-converter would?
My second question is about DO elements (Diffractive Optics). I understand these are used to cut down the len's weight, but seem to make it slower. But the catalogue states "unrivaled image performance".
For example, the Canon EF 400mm f/2.8L IS USM has "conventional" UD glass (Ultra low Dispersion) + fluorite, and weights 5.37Kg :shock: while offering fast optical speed.
On the other hand, the Canon EF 400mm f/4 DO IS USM has DO glass + fluorite and weights less than half: 1.94Kg. But it can "only" offer f/4.
How do these different technologies compare, in therms of image quality? Which one do professionals prefer?
Er... actually, could you please also explain how diffractive optics work and how does ultra low dispersion glass work? :oops:
Nikon D90 + MB-D80 + SB-600 + AF-S VR 18-200mm f/3.5-5.6 + AF-S 35mm f/1.8 + AF 85mm f/1.8 | My photos on Flickr.
PostPosted: Fri Nov 30, 2007 11:17 pm
Hi Luis, a drop-in filter is just that - there's a little door neat the lens mount on the lens where you slot in a filter. They even do some which can be rotated for polarising...
As for DO, there's an explanation here:
http://www.canon.com/technology/canon_t ... _lens.html
