It is currently Fri Jan 20, 2017 12:30 pm
 Post subject: 350D Raw + Jpg Mode...
PostPosted: Sat Sep 29, 2007 9:22 pm
Yeah, I normally just use the RAW Mode, but even the Dual 2Ghz Power Mac G5 is getting killed with all the 8Mp RAW images, so I decided i'd take a few test shots with RAW + L JPG...
...there is no raw file!
it gives me 2 JPG files, both the exact same size, with the same name, apart form the fact the second one has (1), but no CR2 files!
Can anyone explain this? Firmware update needed?
MY FLICKR!
PostPosted: Sat Sep 29, 2007 10:22 pm
Hmmm, that sounds a bit odd... I actually have a 350D here, so just tried it out and in RAW + L mode, it recorded two files, both with the same name, but one is a JPG and the other is a CR2 RAW file. This is how it should operate...
This camera is running firmware 1.0.1...
PostPosted: Sat Sep 29, 2007 10:31 pm
Mine is 1.0.3 ...
MY FLICKR!
PostPosted: Sun Sep 30, 2007 1:11 pm
Is there anyway to downgrade the firmware? or does anyone here have a 350D with 1.0.3?
MY FLICKR!
PostPosted: Sun Sep 30, 2007 11:19 pm
Hmmm, I'm reluctant to update mine now! ANy other 350D owners here?
Daniel, have you tried reseting your camera? Maybe that could help...
PostPosted: Mon Oct 01, 2007 7:09 am
My partner has the 350D, will have a look to see what firmware version she has and if ver. 1.0.3 will try to do both.
PostPosted: Mon Oct 01, 2007 3:32 pm
Thanks mate, report back soon please :D
MY FLICKR!
PostPosted: Tue Oct 02, 2007 9:39 am
Going round her place tonight so will take a look and post my findings later tonight or early AM.
PostPosted: Tue Oct 02, 2007 3:27 pm
Gordon, I didn't see your last post, weird - I'll give it a go later on, not sure If I'm going out again this afternoon to take photos since right not it is pretty bright and sunny with hardly a cloud in the sky, giving me nice, clear blue skies 8)
MY FLICKR!
PostPosted: Tue Oct 02, 2007 4:23 pm
Try reading the card from a card reader instead of using the USB connection directly with the camera. Canon's WIA XP driver does not support CR2 files properly. In fact, it specifically does not support the CR2 + JPEG combo. JPEG files seem to mask CR2 files. You can try to shoot RAW only, and then the CR2 files may show up.
Either way, using a card reader is the simplest solution.
PostPosted: Tue Oct 02, 2007 5:46 pm
They show up on RAW only, I'll grap a card reader from my uncles shop tomorrow and give it a whirl! Never thought Canon would make such crappy drivers....
MY FLICKR!
PostPosted: Tue Oct 02, 2007 9:47 pm
Right Daniel, here is the info you wanted...
'er indoors Canon EOS 350D
Firmware version 1.0.3
Shot one picture using RAW + Large Jpeg
Results
IMG_0122.CR2
So clearly it does work on the 350D with this firmware version.
PostPosted: Tue Oct 02, 2007 10:23 pm
hmm...was that just pliugging the usb into the camera or using a card reader?
MY FLICKR!
PostPosted: Wed Oct 03, 2007 8:15 am
That was using a card reader, you will probably find that if you use a card reader you will get the same results.
PostPosted: Wed Oct 03, 2007 1:01 pm
Yeah, I'll get one on the way home from school tonight!
I'll probably just get a USB card reader rather than one that goes inside the computer since then I can take it with me and use it at school aswell.
MY FLICKR!
