It is currently Thu May 23, 2013 5:51 pm
 Post subject: Sigma 18-200 lens creep?
PostPosted: Sat Apr 19, 2008 5:20 am
I just got myself a copy of this lens, and after a day or two, I found that it suffers from a bit of lens creep when it is in a vertical position. Do other copies of the lenses suffer from this? I don't think it was mentioned in the review.
PostPosted: Sat Apr 19, 2008 4:49 pm
Hi kamui18,
I've moved your post to the Sigma forum as, if lens creep is an issue as you suspect, it will be generic rather than Canon specific. Does your lens have a zoom lock switch and, if so, is it permissible to use it during shooting? I've had a quick look at the PhotoZone reviews for the two Sigma 18-200 lenses and neither mentions zoom creep as an issue.
PostPosted: Fri Aug 22, 2008 4:04 pm
Kamui18,
I just came accross this post because I realized my lens has the exact same problem and I was looking online to see if anyone else had it. I got my lens about one month ago. I guess I had not shot any pictures straight down... and today I noticed the problem. I checked and it does it between 50 mm and 96 mm.
Have you been able to find out if anybody else has this same problem?
Thanks,
Iguana7
