It is currently Sun May 19, 2013 2:08 am
 Post subject: whats this ?
PostPosted: Sun Jan 13, 2008 2:34 pm
http://www.jessops.com/Store/s27349/0/Lenses/Canon/07x-Wide-Converter-Lens-For-Powershot-S1-IS/details.aspx?&IsSearch=y&pageindex=1&comp=n
whats this im confused :s
canon 400D kit 18-55mm lens + Sigma 70-300mm F4-5.6 APO DG MACRO
 Post subject: Wide angle lens
PostPosted: Sun Jan 13, 2008 3:25 pm
You put that converter into the specified camera and you have wide angle added to your camera.
This one says "Converts the focal distance of the body lens by a factor of approximately 0.7x (35mm film equivalent at maximum wide angle: approximately 26.6 mm) when attached"
In this case you can put this converter in the Powershot S1 IS and get wider angle capabilities. This one is for this specific model.
Carlos - Caracas Venezuela
EOS 40D
Tamron 17-50mm f/2.8 XR Di II LD/50mm f1.8II
my flickr
PostPosted: Sun Jan 13, 2008 3:29 pm
oooooooooo
so you put it onto the lens and it makes it wide angle yea?
can you get then for dslr's?
PostPosted: Sun Jan 13, 2008 3:42 pm
:o I have seen them for point & shoots but I don't remember if they are available for dslrs.
My guess is that there are some for dslrs. :)
If I find one I'll send you a msg.
EOS 40D
my flickr
