It is currently Sat Jan 21, 2017 11:26 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 05, 2009 8:05 pm
It's not always down to user error :)
Some lenses have an issue with focusing, either back focusing (actual focus is slightly behind desired focus) and front focusing (actual focus is in front of desired focus). These are much more obvious at large apertures since the DoF is razor thin.
I'm much more interested in the f1.4 shots since any lens goes to f5.6 and more :)
PostPosted: Thu Feb 05, 2009 8:20 pm
All at f/1.4
PostPosted: Fri Feb 06, 2009 4:06 am
what makes this lens better or worse then the NIKKOR? I appreciate a good lens, but is between $400 and $500 reasonable for sigma?
I really like the output (pics)...
PostPosted: Fri Feb 06, 2009 4:16 am
I was originally going to get the Nikkor (1.4g) but after it finally came out and nobody had it I started looking around, found a positive review on the Sigma, and another and another... before long I had read a lot of great things about it and it was available and cost less than the Nikkor at the time.
I'm sure they are both equally good lenses, I have no regrets and would recommend it to anyone without reservation.
That said, I've only been shooting with my D40 for about 3-4 weeks now and only knew what aperture and shutter speed do for about that same amount of time.
:D
For me, my main goal and purpose for this camera was portraits of the kids - I'm more than confident I can pull that off now.
PostPosted: Fri Feb 06, 2009 8:05 am
Your shots seem a bit soft for my taste. How as the lighting? It almost seems as if there is some blur from camera shake\low lighting. Try some shots with an external flash
Canon EOS 450d/XSi, BG-E5 Grip, 4 LP-E5 battery, Canon EF-S 17-55 F2.8 IS USM, B+W 77mm Pro1 MRC UV0 filter, Canon EF-S 10-22mm USM, HOYA 77mm HMC UV(C) Multi-Coated Filter THIN, Canon 580EX II,
http://www.flickr.com/photos/31510271@N05/
PostPosted: Fri Feb 06, 2009 11:08 am
Handheld, wide open and indoors lol... pretty much a recipe for soft.
PostPosted: Fri Feb 06, 2009 11:35 am
Unless you have IS built into your camera. Oh wait ...
:P
PostPosted: Fri Feb 06, 2009 11:53 am
Sigh... :oops:
PostPosted: Sat Feb 07, 2009 6:50 am
I also got my sigma 50mm just today,
i took this first pic with it from inside my home thru a window.
F/1.4
iso 200
