It is currently Fri May 24, 2013 6:23 pm
 Post subject: cheap 50mm f/0.95
PostPosted: Tue Jan 06, 2009 6:12 pm
Now that I got your attention, I'll have to explain. While looking for something else, I found a lot of "affordable" 50mm f/0.95 lenses on ebay. After the wow factor wore off it was time to figure out the practicalities.
Firstly they're C-mount or similar. As far as I understand this is used in security cameras and such like. The register distance (distance from mount to focal plane) is 17.5mm. Problem 1: most DSLRs are around 40mm or higher. Problem 2: the intended image circle are typically smaller even than APS-C so it will probably vignette.
There's no getting around problem 2, so the question remains what would it be like to fit to a DSLR? Assuming you had a mount adapter, it would fit as if you put an extension tube on for macro work. You will lose infinity focus and be limited to close up work.
One final thought appeared though - micro four thirds format. With the mirror binned, that has a register distance of 20mm so it is really close. With a little physical hacking of the lens body that might even fit.
Todo: work out how extension tubes affect focal distance.
Anyway, they're not quite cheap enough for me to experiment with in this respect, but if you want a really fast lens for macro use this might be something more exotic to play with.
PostPosted: Tue Jan 06, 2009 7:13 pm
We've just had a thread on a similarly specified lens over in the Canon section which you can read here. Are the lenses you are talking about definitely C mount or are they actually the Canon S mount lenses fitted with an adaptor?
PostPosted: Tue Jan 06, 2009 8:05 pm
The ones I found were not by Canon. The Canon lenses are listed for silly money.
Having said I found a load, they all seem to have disappeared since the last time I looked with the only one left which isn't C mount.
Also it appears I'm far from the first to have this idea. Here is a 25mm f0.95 with micro fourthirds adapter that apparently sold.
PostPosted: Wed Jan 07, 2009 2:51 pm
Or you can save 12.000 $ for the Leica 50mm F/0.95. :) (a little joke there)
You'll sell your car or something,but hey! It's a Leica! :lol:
Visit my work here
PostPosted: Wed Jan 07, 2009 5:49 pm
I'd need to sell more than my car to get that!
But on the focal distance issues, I wonder if a simple diverging lens of some sort will fix that?
PostPosted: Fri Aug 14, 2009 7:03 pm
Im not sure if this will work, but the way i see it, theres only one thing to do:
get some kind of adapter that works (canon to c or whatever mounts), and if this does not excist, you have to make one yourself. once you get a hold of one of these, you have to split it in two, and mount a tube (material not important, but inside must be non reflective) with the lenght equivalent of the difference between the two register distances (40mm - 17.5mm) and simply glue both halfs on each end of the tube, then it should be fixed? ;)
but really, i dont know about how to fokus and so on, i just came to think of it ;)
sorry for the long and difficult explanation :P
Regards, Morten
Sony A200
Minolta 100-300 APO, Minolta 70-210 f4
Minolta 50mm F1.4, Minolta 24mm f2.8
Minolta 28-135, Sigma 90mm f2.8 Macro
PostPosted: Fri Aug 14, 2009 7:12 pm
The problem is not adding more length, it is taking some away. We would need a negative length tube here...
It doesn't matter anyway. Seems with the launch of micro Four Thirds format, the cheap C mount lenses have jumped up in price and the big aperture ones hardly show up at all now.
