It is currently Tue Jan 17, 2017 7:18 am
 Post subject: Garden wildlife
PostPosted: Tue Mar 11, 2014 6:02 am
Two pics from yesterday.
Ladybirds, which clearly feel that Spring has arrived.
Ladybird Spring by warth man, on Flickr
Male blackbird, with last inch or so of wriggly worm about to go down the hatch.
End of a worm by warth man, on Flickr
 Post subject: Re: Garden wildlife
PostPosted: Wed Mar 12, 2014 1:10 am
Good shots to capture, I would suggest when shooting dark coloured things use +EV. If your using elements 10 and shot a jpeg, open it as a camera raw file which will enable you to use different EV setting.
PostPosted: Thu Mar 13, 2014 5:56 am
Thanks for that 4xxxx. I didn't know PSE 10 gave that option. I'll check it out. As it was, this was shot in raw and was an opportunity shot. Unfortunately I missed the pic of the worm being pulled out of the ground.
PostPosted: Fri Mar 14, 2014 12:31 am
Not sure about PSE 10, I posted this a while back.
viewtopic.php?f=26&t=33303&hilit=raw
PostPosted: Fri Mar 21, 2014 10:18 am
Very Spring-like that's for sure. I can't remember the last time I saw that many ladybirds in one spot. It looks like your weather up north is a lot warmer than what we've had in South Wales; very envious :wink:
Camera: Panasonic Lumix GX1
Lenses: Lumix G Vario 14-42mm f3.5-5.6, Lumix G Vario 100-300mm f4-5.6 and Samyang 7.5mm f3.5
with adapter: Nikon 50mm f1.8 and Tamron 24mm f2.5
