It is currently Wed May 22, 2013 5:44 am
PostPosted: Sun Dec 02, 2007 8:45 pm
Hey everyone,
My friend asked me to take some pictures of his fish in his aquarium with my new D80 with 18-70mm.
Do you guys have any tips as how I should go about doing so?
I would assume I will need a high shutter speed since the fish move quite a bit but other than that, I'm not sure where to start.
D80 || Nikkor 18-70mm DX
PostPosted: Sun Dec 02, 2007 10:25 pm
Just take the widest angle (i.e. 18mm), put on the lens-shade, direct all the light into the aquarium and switch off any unnecessary ambient light to avoid reflections. If you press the shade against the aquarium wall you can make steady shots without tripod, without reflections and without shake at 1/15 or even 1/8 sec.
Just try it out before you up the ISO to shoot at shorter speeds...
PostPosted: Sun Dec 02, 2007 10:46 pm
I did virtually as Thomas described for a test shot with the Pentax *istDL two years ago - scroll down on the Gallery page for it here:
http://www.cameralabs.com/reviews/Penta ... age5.shtml
PostPosted: Fri Dec 07, 2007 2:59 am
Alright -- well for small aquariums and small fish you need a flash or really fast lens.
So trying without the flash here's the best I was able to do (in regards to noise and sharpness):
http://ewoutvb.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=145&g2_serialNumber=4
Then I made my own ghetto flash diffuser for the built-in flash...
http://ewoutvb.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=263&g2_serialNumber=1
And here's a quick preview without much work, I can probably do much better (sorry about the dirty tank):
http://ewoutvb.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=271
PostPosted: Fri Dec 07, 2007 11:14 am
Hi Ewout_vB,
If you have a polarising filter, that's another very good way to reduce reflections off the glass.
PostPosted: Fri Dec 07, 2007 2:02 pm
Thanks for the suggestion!
I'll see if one of my friends has one so I can stack it really quick and try it out to see if it's worth it :D .
