It is currently Wed Jan 18, 2017 4:20 pm
 Post subject: Splash
PostPosted: Wed Nov 28, 2007 11:15 pm
My first attempt at a macro of a splash. Let me know what you think!
Olympus E-510
14-42mm kit lens at 39mm
1/5 sec
f/8.0
Used pop-up flash.
PostPosted: Wed Nov 28, 2007 11:21 pm
Great! But 1/5 sec shutter speed coul dnever freeze that drop!?
Ah, the flash did the job...
D810+assorted lenses
PostPosted: Wed Nov 28, 2007 11:50 pm
That's a great photo! How many drops did you have to try, to get to this one?
So if I understand correctly, it doesn't matter how much time the shutter was open, because the sensor only picked up enough light while the flash was firing?
PostPosted: Thu Nov 29, 2007 6:31 am
If I understand correctly, once the flash is used the shutter speeds drops to 1/60.. :roll:
 Post subject: i tried it
PostPosted: Fri Jan 04, 2008 3:57 am
i attempted to do this very trick with my nikon d40x. the shutter was set on priority so i bumped it up to 1/200 and used the cameras built in flash with half of a napkin as a diffuser. here are some of the photos in a flash gallery on my page i would love some input as far as equiptment to invest in because i love taking these types of pictures.
ps the gallery is a flash gallery.
http://ampedpss.com/images/Gallery/lightroom/photography%20jan2%20water%20drop/water%20drop%20jan%202/index.html
PostPosted: Fri Jan 04, 2008 8:59 am
Using a slightly slower shutter speed makes the lighting less harsh and the background brighter while still freezing the motion of the water.
PostPosted: Fri Jan 04, 2008 7:45 pm
Is that the idea behind Slow-Synch Flash and Rear-Curtain Flash ? I was always wondering about that.
I have tried those two options and the normal flash mode and the best results were given by Slow-Synch and Rear. The problem though is that the shutter speeds were quite low and it brings blur and motion into pictures :(
For your water drop shot though it doesn't seem to be the case. How come?
The shot is very nice btw! I looks like a glass made of water.
