It is currently Fri Jan 20, 2017 6:21 pm
 Post subject: Need a Macro Lens
PostPosted: Sat Oct 18, 2008 2:35 am
Hey Pentaxians,
I am planning (really soon) to get a decent macro lens, as I want to get a little more serious into outdoor photography. I have read many reviews and I have narrowed my choices to Pentax D-FA 100mm f/2.8 and the Sigma 105mm EX f/2.8. At first I was really looking toward the Pentax, but then I found the Sigma on Amazon for only $350 (Pentax is around $400 on one site). Anyone have any experience with either of the lenses? And yes, I have heard some bad things about the build quality of the D-FA 100mm compared to its predecessor. Your opinions are highly appreciated!
Samsung GX-10, , SA 18-55mm
www.flickr.com/glxlr
PostPosted: Sat Oct 18, 2008 10:40 am
Hi GLXLR,
Both lenses have been reviewed over at PhotoZone. The Sigma was reviewed on both Canon and Nikon bodies (no Pentax review, I'm afraid) and it seems a solid performer. The dangers of comparing reviews are amply illustrated by the difference in the results between the two Sigma tests, however.
PostPosted: Sat Oct 18, 2008 11:46 am
The Sigma 70mm is better optically than the 105mm,in fact the best macro third party I know. It comes down to what range you want.
PostPosted: Sun Oct 19, 2008 12:37 pm
Hullo
I recently bought the Sigma 50mm f2.8 ex having considered the other lenses you mention. (but discounted them fairly early as 50mm was the focal length I wanted)
The 70mm sigma seems to be the pick of the bunch in terms of sharpness but I wanted something for macro work that could double up for some portrait work as well which is why I chose the 50mm.
I haven't used the other two you mention but the 50mm get's extremeley close to produce 1:1 results so using it for insects (other then dead or very slow ones) it's pretty useless. (I knew this before I bought it)
That said the pictures so far from this have been excellent with the only failings being my own.
One thing I was interested in was that the Sigma would cover full frame as well (the pentax 50mm macro did not) so it may be worth checking this with your choices so that when Pentax/ Samsung hopfefully do offer a full frame body your lens can alossbe used on that should you choose to.
:o)
K10D + optimistic idiocy
My pic's - http://www.flickr.com/photos/10126769@N05/
PostPosted: Mon Oct 20, 2008 6:28 am
DFA lenses are FF compatible.
PostPosted: Mon Oct 20, 2008 8:41 am
Bonjour,
I'm very happy with my :arrow: Pentax DA* 50-135mm f2.8 ED (IF) SDM for :arrow: macro photography.
Large aperture f/2.8 gives :arrow: extra freedom for depth of field effects.
Check :arrow: my review :)
--- rei_vilo
reivilophotography.weebly.com
PostPosted: Fri Oct 24, 2008 11:29 pm
the Sigma 105mm and the Tamron 90mm are good options.. I would go for the Sigma because of the 105mm.. for animals the distance is better. The Pentax is too expensive and its not better.
