It is currently Mon May 20, 2013 12:32 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 08, 2012 9:39 am
The X-Pro 1 is starting to look rather interesting. Leica Rumors report that "Fuji will announce their own M-mount adapter for the X-Pro 1. The camera will also have two optical magnification options: x0.37 for wider lenses and x0.60 for other lenses."
Photo Rumors also report that the "new sensor called X-Trans is a classic 16-megapixel. RGB filter is arranged in random blocks of 6x6 pixels which avoids the need for AA filter. This design requires a faster processor - the X-Pro 1 has a new EXR Processor Pro." They also report that it will have a "similar hybrid viewfinder like in the x100".
With a decent set of primes expected at launch as well it looks as though Fuji may have a winner on their hands if they price it right and would also seem to be squeezing Leica towards a full-frame sensor for their own pre-announced non-rangefinder CSCs expected towards the end of this year.
PostPosted: Sun Jan 08, 2012 9:57 am
I think I just heard a collective groan from RAW converter developers from the headaches they'll surely have over the "random" colour filter arrangement. Unless I stepped through that lecture, using non-regular sampling spaces wasn't something I recall being covered when I was in university... my thought at this time is that regardless of the sample method used, you still need an AA filter to be mathematically optimal. Fixed pattern sampling can result in moire if not adequately filtered, and I'm guessing the non-regular pattern would disperse the moire into random-like noise. It doesn't get rid of it as such, just makes it look less visible. My primary concern would be if this arrangement will impact on pixel level details.
PostPosted: Mon Jan 09, 2012 10:27 am
Hi Dutch,
I've updated the thread title to include the model name. Hope that's OK?
PostPosted: Mon Jan 09, 2012 10:29 am
Word is that the Fuji press conference announcing the X-Pro 1 happens at 20:00 GMT tonight (12:00 PT). I guess the usual suspects will be covering the launch as well as those sites running live CES updates. Can't wait... 8)
Update: Still not official but here are some of the specs that really jump out at me:
  • Image sensor: 16.3 million pixels (23.6mm×15.6mm APS-C)X-Trans CMOS with primary colorfilter
  • Movie format: H.264(MOV)with Stereo sound
  • Sensitivity:Equivalent to ISO 200 – 6400 (Extended output sensitivity: equivalent ISO 100, 12800 and 25600)
  • Shutter control: Focal Plane Shutter, Shutter speed (with mechanical shutter)” “(P mode) 1/4 sec. to 1/4000 sec., (All other modes) 30 sec. to 1/4000 sec. Bulb (max.60min.) Time 2 to 30 sec
  • Continuous shooting: Max 6 / 3 fps selectable
  • Auto bracketing: AE Bracketing (±1/3EV, ±2/3EV, ±1EV)
  • Viewfinder: Hybrid Multi Viewfinder, Optical viewfinder. Reverse Galilean viewfinder with electronic bright frame display. Magnifications: 0.37x / 0.6x
  • Electronic viewfinder 0.47-in., approx.1,440,000-dots color LCD viewfinder
  • LCD monitor: 3.0-inch RGBW (White) LCD monitor, approx. 1,230,000dots, (Approx. 100% coverage)
  • Dimensions: 139.5 (W) mm x 81.8 (H) mm x 42.5(D) mm / 5.5in.(W) x 3.2in. (H) x 1.7 in. (D) (Minimum depth: 34.1 mm/ 1.3 in.)”
  • Weight Approx: 450g / 15.9 oz. (including battery and memory card) Approx. 400 g /14.1 oz. (excluding accessories, battery and memory card)
    Source: MirrorlessRumors
PostPosted: Mon Jan 09, 2012 8:36 pm
Here's what the X-Trans sensor's Bayer alternative looks like, direct from the press conference:
They are talking $1700 for the body and $650 for the lenses, but that is to be confirmed. Methinks they live on a different planet. :roll:
On the good side, if Leica were planning an APS-C EVIL, rather than a full frame one, then Fuji may have done them a big favour with that SRP. :twisted:
PostPosted: Mon Jan 09, 2012 9:47 pm
I've split out the official announcement for a new sticky thread and locked this one - thanks!
