It is currently Wed Jan 18, 2017 6:40 am
PostPosted: Sun Sep 27, 2009 5:53 am
Curious, is it possible to remotely trigger this DSLR using a laptop and the supplied USB cable? If so, could you point me to the software I'd need to use for this?
Thanks! :)
PostPosted: Sun Sep 27, 2009 9:59 pm
Bonjour Zoeff,
Yes, it is possible :)
The software name is Pentax Remote Assistant. Normally, it's included on the Software CD supplied with the camera. I tested it with my K10D.
Now, it seems the Pentax Remote Assistant is no longer bundled with the K-7 (who knows why :?: ).
Check the :arrow: K-7 user manual and the :arrow: Pentax Remote Assistant user manual.
Best regards,
--- rei_vilo
reivilophotography.weebly.com
PostPosted: Mon Sep 28, 2009 12:19 am
Ah, that looks very promising! Thanks! :)
PostPosted: Mon Sep 28, 2009 6:02 am
Bonjour Zoeff,
You're welcome :!:
Here are the Remote Assistant tests I performed on my K10D User Review
:arrow: http://www.cameralabs.com/forum/viewtopic.php?p=3888#3888
:arrow: http://www.cameralabs.com/forum/viewtopic.php?p=7318#7318
Enjoy :)
--- rei_vilo
PostPosted: Mon Sep 28, 2009 12:47 pm
Correction, it's actually a K20D. Shouldn't matter much but still..
A few questions...
Just tested the remote assistant software and couldn't figure out how to get a live image. Is this even possible?
If it isn't, might it be possible to lock the mirror to prevent it from flipping?
I'm planning on using this DSLR for astro-photography so the mirror flip will cause a huge amount of unnecessary vibration. :(
PostPosted: Mon Sep 28, 2009 1:57 pm
Bonjour,
No, there's no live-view. One trick: shoot a 1st time to get the image and then a 2nd time for the real picture.
To lock the mirror, press Function, then Up, then 2 s delay.
Some parameters are managed by the Remote Assistant software and others directly on the K10D / K20D.
Have fun :)
--- rei_vilo
PostPosted: Mon Sep 28, 2009 2:39 pm
2 seconds might not be enough but it's much better then nothing.
If I ever manage to get a decent looking image I'll be sure to post it on these forums. :D
Thanks!
PostPosted: Sat Jan 30, 2010 3:38 am
i was skimming pentaxs remote assistant manual; pentaximaging.com/files/scms_docs/software_drivers/remote_assistant/ra_manual.pdf , for some of that info to no avail, thanks! party supplies
PostPosted: Sat Jan 30, 2010 3:46 am
My K200 has 2 and 12 sec, suspect yours does also :wink:
Pentax K-5
PostPosted: Thu Mar 25, 2010 1:43 pm
Hi guys, just wanted to say hi.. will enjoy catching up reading on the forum :D
