It is currently Wed May 22, 2013 11:41 am
 Post subject: Macro Extensions
PostPosted: Sun Oct 07, 2007 4:09 pm
Anyone ever use them? And also, are they needed with a macro lense?
Random Factoid: It's Sunday right now and the washer sounds like a helicopter. Stupid energy efficient washers. :P
Sorry, mate, I believe I just ate your pudding cup.
PostPosted: Sun Oct 07, 2007 5:32 pm
No extension tubes needed with a macro-lens.
But you can also use them to extend the magnification of the macro-lens.
Unfortunately the IQ will suffer esp. when just using a "normal" lens or a zoom, as you'll leave the parameters that this lens was corrected for.
Alternatives:
Use a well corrected close-up lens to screw in front of your camera-lens (Canon 500D at around 100$).
Or use a tele-converter (more expensive) that improves magnification by the same factor as the focal length of your lens (max. 2x), so if your lens went down to say 1:3.8 it will go down to 1:1.9 with a 2x tele-converter.
IQ-wise the close-up lens might be the best alternative, as the tele-converter halves the resolution of your lens.
But to answer your question directly: no, I have no experience with extension tubes :(
