It is currently Sat Jan 21, 2017 9:00 am
PostPosted: Wed Aug 27, 2008 5:12 pm
When a lens is full frame does it work on a cropped frame
I was looking at this lens on ebay as an example
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=001
would it fit on a a300 (assuming the mount is ok)
what the effect of putting a full frame lens on a cropped body and vice versa?
PostPosted: Wed Aug 27, 2008 5:18 pm
It does work on cropped sensors but your focal length is multiplied, so the 12-24 would become something like an 18-36mm lens.
PostPosted: Wed Aug 27, 2008 5:46 pm
They say this lens fits only Sigma cameras so it would not fit your Sony A300.
PostPosted: Wed Aug 27, 2008 8:01 pm
is that the same multiplication that any lens would get from a cropped frame? ... i.e. if i got the sony 11-18mm its lower end would be comparable?
The sigma website says the lens fits sony as well :s
PostPosted: Wed Aug 27, 2008 8:19 pm
Sigma make different versions of their lenses for different brand of cameras. So they make a 12-24 for a Nikon, for a Canon, for a Sony etc. but they are different lenses and the Sigma lenses built for Nikons won't fit on Canon or Sony cameras.
PostPosted: Wed Aug 27, 2008 8:40 pm
Yes, any DSLR that uses an APS-C sized sensor will have a zoom factor of 1.5 compared to the traditional full frame DSLR and film cameras. That means that your 12 - 18 mm lens will will be equivalent to 18 - 27mm on the APS-C sensors.
You should multiply all focal lengths you see by 1.5 if you want to work out what it actually is on an APS-C sensor.
Sigma makes lenses for most cameras. However, each lens mount (i.e. the connector that links the lens to the camera) is different. So a Sigma lens that has the Nikon AF mount will not work on Canon and Sony cameras and vice versa.
PostPosted: Thu Aug 28, 2008 9:31 am
Keep in mind that the Sigma 12-24mm will fit on future full frame bodies, but the Sony 11-18mm won't. If you think you might buy a full frame camera some day, the Sigma may be a better choise. Just make sure you get the Sony-mount version though :D.
