It is currently Sat May 18, 2013 11:44 am
 Post subject: Alpha battery grips??
PostPosted: Sun Aug 24, 2008 9:56 pm
Hey guys,
I have got a Sony A200 and I am looking at buying a battery/portrait grip...
I noticed that there are 2 types. one for a200 a300 & a350 and one for a700.
If I was to purchase the grip for the a700 will this be compatible with a200?
The reason i ask is that i may pgrade my camera and it would be nice to be able to use the same grip as I could with the lenses?
Any Ideas?
Sony Alpha A200 with 18-70mm kit lense & Sony DSC-H9 with Sony 1.7x telephoto lense.
PostPosted: Sun Aug 24, 2008 10:04 pm
I believe the grips are different as the cameras have different sizes/placements of bits where they fit. So the wrong one wont fit.
If you get the correct one for now, remember you can still recover some of the value by reselling if you later upgrade.
PostPosted: Sun Aug 24, 2008 11:33 pm
BG30 only goes with the A200, the A300 and the A350 whereas the BG70 only goes with the A700 :D
Gear:Sony Alpha a350, Sony H9, Nikon FM-10
Gear:CZ85mm F/1.4 Planar, CZ24-70mm F/2.8 T* ssm, Sony 70-200mm G F/2.8 ssm, Sony 50mm F/2.8 macro, Nikkor 35-70mm
PostPosted: Mon Aug 25, 2008 12:37 pm
The VG-C70AM (corrected you Joey :wink: ) grip is only compatible with the Alpha 700 (not with the future A900 either). You'll have to get the VG-B30AM for your A200 (or A300/A350).
See the Alpha compatible Lenses and Accessories guide for more info!
PostPosted: Mon Aug 25, 2008 11:36 pm
Thanks Bjorn yeap i was so stuck with the term BG as in battery grip :oops:
"WOOOAAH" this is my 100th post!!!!!!!!!!!!
PostPosted: Thu Aug 28, 2008 10:11 am
Congratulations! 100 posts, I see you're at 114 already.
Coming closer to 1100 myself...
The BG for battery grip makes sense. However, the VG is short for vertical grip, which is what they're often called.
- Bjorn-
