It is currently Sat May 25, 2013 8:18 am
PostPosted: Tue Nov 15, 2011 9:15 pm
Where the heck is the two second timer on the NEX-5N I have looked and looked and can only find the ten second, which is way too long, for just not wanting to touch the shutter button to reduce shake: Larry
PostPosted: Tue Nov 15, 2011 9:36 pm
If you found the 10-second timer...then you also found the 2-second timer!
Go to the 10-second timer in the drive mode selections until it's highlighted...then hit the bottom button which should say 'Options'. That will place a box around the 10 seconds, with an up and down arrow, allowing you to switch between 10 or 2 seconds. Choose 2 seconds with the up or down arrow.
Justin Miller
Galleries:
 Post subject: Thanks so much
PostPosted: Tue Nov 15, 2011 9:56 pm
I have looked in every manuel, Thanks, I really needed to find that 2 second delay as I shake pretty bad. : Larry in east TN
