It is currently Sat Jan 21, 2017 12:42 am
 Post subject: Image Quality
PostPosted: Tue May 03, 2011 9:43 pm
I am looking to up date my current dslr. I currently own a Nikon D40.
I am looking at the A55 as a possible replacement. I am impressed with the auto focusing. Is the image quality going tobe simlair to a Nikon or an Olmpus?
PostPosted: Tue May 03, 2011 10:50 pm
You can compare sensor performance here
http://www.dxomark.com/index.php/Camera ... ed-sensors
Also read Gordon's reviews
PostPosted: Tue May 10, 2011 2:13 am
To save you a bit of time, I have a load of A55 results in my Canon T3i / 600D review, see:
http://www.cameralabs.com/reviews/Canon ... ults.shtml
On the high ISO noise page you'll also see some results for the multi frame NR mode...
PostPosted: Tue May 10, 2011 3:58 pm
And a basic answer to your question which hasn't directly been answered yet: YES. Image quality on Sony DSLRs will be directly comparable and essentially equal to that of Canon, Nikon, Pentax, and Olympus at the comparable level of camera.
All of the brands make cameras capable of near equal image quality - key differences come down to ergonomics, features, sometimes high ISO performance, lenses used, and photographer skill.
You will find Sony, Nikon, and Pentax have the closest performance similarities, since all three use the same sensors (made by Sony) in comparitive models. Canon has sensors of similar ability and quality at the same model equivalence. Olympus will basically equal the others in good lighting, and fall slightly behind as the ISO levels get higher, since they use a slightly smaller sensor not quite as capable in extreme low light situations.
Some models of every brand are better than other models - Sony, Nikon, Canon, Pentax etc have entry level cameras with less features and slightly lesser sensors, mid-level models with higher-spec sensors and better features, and all but Pentax have full-frame models with huge sensors for pro-level work.
Justin Miller
Galleries:
