It is currently Tue May 21, 2013 3:41 pm
PostPosted: Sat Jan 15, 2011 11:09 am
I just came across a Sony Lens the 500 F8 super reflex.
there is a bit on it here
http://www.luminous-landscape.com/revie ... y500.shtml
Quite interesting, if they can fix a few of those issues mentioned, it might be a great little lens
PostPosted: Sat Jan 15, 2011 12:34 pm
Im almost sure it's a mirrorlens.
PostPosted: Sat Jan 15, 2011 12:56 pm
It is a mirror lens and there isn't anything to fix. If you make one in that configuration, that's what it does. If you want more or different, you need to make something different, which would then be something else.
PostPosted: Sat Jan 15, 2011 3:09 pm
It's the only autofocusing reflex lens in the world as far as I know. It has a fixed aperture, so exposure can only be set using the shutter speed and ISO. Also, I've read and heard that will set your AF point selection to the center one - you can't use it with all your AF points.
My photos on Flickr...
