It is currently Mon Jan 23, 2017 6:54 am
PostPosted: Sun Aug 01, 2010 8:53 am
Just a quick question to those more experienced with advanced settings...
Is there an easy(ish) way to get this camera to reliably focus at infinity without going the trial-and-error route?
The reason I ask this:
I recently started into astrophotography, andd I'm having a bit of difficulty getting my H5 to focus at infinity, manually or otherwise. The Moon is no problem - autofocus works just fine - but trying for some of the brighter planets (Venus, Jupiter) leaves it either hunting or significantly off-focus.
Thanks in advance!
Floyd.
PostPosted: Tue Aug 03, 2010 5:01 pm
It's been a few years since I've had my H5, however I remember that it had a manual focus mode that I used when I was shooting low light or night sky photography and needed infinity focus. The focus selection button on top should give you that option, then you use the control pad to move the on-screen focus bar over to infinity. Remember that sometimes true infinity focus is actually just a hair back from the farthest setting - many cameras actually adjust focus a bit 'beyond' infinity. Without a way to magnify the screen, it may be hard to determine accurate focus, but that should get you pretty close. If you can find a star that's brighter, the H5 has a 'peaking' function in MF mode which will highlight the areas in blue that are in focus to help you get it right. In manual focus mode, you can always find a larger object like the moon to focus on, then recompose and meter off of the area you intend to shoot - the manual focus will stay where you set it so you don't get all the hunting around trying to AF.
Justin Miller
Galleries:
PostPosted: Tue Aug 03, 2010 6:29 pm
You can AF on streetlight in the distance, that works the same;)
PostPosted: Thu Aug 05, 2010 12:07 pm
Thanks, guys - that's pretty much what I've been doing.
I was hoping that there was a setting like my Oly E510 has where you can hit a separate button to get a one-shot auto then it reverts to manual.
I guess that it really isn't so bad to spend a few minutes at the beginning of a session fine-tuning the focus. <shrug>
BTW - Exactly how far away would something need to be to be considered at "infinity" for focus purposees?
Floyd.
