It is currently Sun May 19, 2013 6:43 pm
 Post subject: A850 Sync speed
PostPosted: Wed Apr 14, 2010 12:29 am
Hey guys,
Did a quick experiment (for no particular reason), and I was able to get full sync with the AB800 consistently at 1/320th and occasionally at 1/400th (with steadyshot off). I was hoping to get it up higher since some cameras, namely the D70 can sync up to 1/1250th, even though rated at 1/500th.
Does anyone know of a way to get the sync speed up without using a Sony propriety flash?
Please note that I was only able to do this by using a PC sync cord. Using the cybersync triggers didn't work.
PostPosted: Wed Apr 14, 2010 5:56 am
How do you get it to sync at anything other than the maximum rated shutter speed? Doesn't HSS immediately get enabled when you go above the maximum sync speed?
PhilipGoh.com
PostPosted: Wed Apr 14, 2010 9:31 am
what does it matter?
Aperture controls exposure when using flash.
a flash is 1/10,000 of a second a quick shutter speed will only "catch" the shutter.
http:/dowdenphotography.com/
Camera: who cares its the photographer
Lens: Lots
PostPosted: Wed Apr 14, 2010 9:47 am
I think this works because the AB800 was able to expose the entire frame since the sensor was exposed fully for the duration of the flash. Its also possible that 1/320th only works under certain situations so Sony decided to stick with 1/250th which is the mechanical shutter speed (playing it safe). But, some cameras are able to achieve high sync speeds, particularly D70 and G1, so I guess it depends on how the sensor is scanned at high shutter speed.
You can get more info here http://strobist.blogspot.com/2007/05/hacking-your-cameras-sync-speed-pt-1.html
@Sdowden: There are a couple of reasons why a faster shutter speed is important. You are correct that aperture does control flash exposure, but in a situation where the ambient exposure is say 1/1000th, syncing at 1/250th will cause a significant amount of ambient light to be within the exposure and in some cases may result in overexposure. This typically happens when shooting outdoors in bright sunlight. You can walk up the power of the flash and shoot at something like f22, but then your'e dof is huge at that point. Also, some action scenes will still show significant motion blur at 1/250th, for example sprint and car races. So, in order to freeze motion and get sharp results, a higher shutter speed is essential (or a very short t1 duration, providing the ambient exposure is "correct" at 1/250th).
Hope that makes sense.
