It is currently Wed Jan 18, 2017 12:37 pm
PostPosted: Wed Jan 20, 2010 2:51 pm
Having used Tamron 18-250mm f/3.5-6.3 lens for about a year I've been generally happy with the range and optical quality it provides. However I recently attempted to shoot some flying birds and found the lens to be slow at the longest 250mm end. It was not able to focus fast enough to track a flying bird which resulted in blurred photos of the subject as it took long time for the lens to decide where to focus, the subject (bird) or the background (some trees and plants).
I heard that the equivalent Sony 18-250mm f/3.5-6.3 lens is optically identical to the Tamron version but is "a bit faster". So my question is: would this translate to any significant difference in the wildlife photography, particularly tracking fast moving object? Or the difference is so negligible that it is not worth of upgrading to the Sony version? The price difference between the two lenses is about 100 $.
PostPosted: Wed Jan 20, 2010 4:39 pm
I doubt that you will find much difference between the two.
The lens is slow for action shots, I usually delete about 90% of my speedy captures, but the ones that lock look great.
PostPosted: Wed Jan 20, 2010 5:24 pm
While the Sony version has a reputation of being faster to focus than the Tamron, without 1st hand experience its hard to quantify how much difference there will be.
Having said that, focus speed shouldn't affect the blurryness of the image as long as it is in focus, which then depends on shutter speed and movement of the camera or subject.
As a side though, how about looking at a 70-300 lens instead?
PostPosted: Fri Jan 22, 2010 3:36 pm
Ok, I guess I should not bother with it then.
Popo, do you mean the kit 70-300mm lens? I had it before and there were problems with chromatic abberation at the 300mm end. The G lens would be nice but it is not universal for travel which is why I will stick with 18-250mm lens.
PostPosted: Fri Jan 22, 2010 5:32 pm
The Sony version is 75-300 unless you fork out for the high end 70-300G.
I was thinking more of the Tamron or Sigma versions. More Tamron to avoid possible gear stripping issues.
