It is currently Tue May 21, 2013 6:14 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Aug 22, 2009 3:00 pm
primitive wrote:
P.S. Those pieces of wood look well cut, almost pre-cut :) ... just kidding, those guys look like they mean business!
Believe me, those are real.
I can't even break 1... :oops:
Those are red belts, if they pass, they will get black belt(which is the highest ranking belt)
Anyway, if you are going into a commercial state, i don't understand why you are still using a body designed for newbies?
Must be an awesome camera then, to make you continue to use it :D
I say you deserve an A900! :wink:
Tamron 17-50mm F2.8
Tamron 70-300mm F4-5.6
Sony F58
PostPosted: Sat Aug 22, 2009 3:43 pm
Gold_Fish! wrote:
Here are the pictures from the taekwondo grading held in my school. All taken at ISO 1600
I notice that they're converted using DXO ;)
DXO increases your camera's usable ISO by roughly 1 stop and it also happens to be the best converter for high ISO shots.
PhilipGoh.com
PostPosted: Sat Aug 22, 2009 5:01 pm
Well the Sony A300 is not supported by DxO, only A100 and A900. I shot JPEG with NR off(NR is still applied to Jpeg) then used noise ninja with batch edit.
The CA, distortion and crop were corrected by DxO manually... :oops:
Notice how the back ground is so bright yet there are no CA :wink:
Tamron 17-50mm F2.8
Sony F58
PostPosted: Sat Aug 22, 2009 5:48 pm
The current version of DxO does support A200/A300/A350, although in a quick scan it doesn't look like they have those Tamron lenses done for it though.
PostPosted: Sun Aug 23, 2009 12:35 am
Hi everyone, I just uploaded full res samples of the A380 at each ISO to our new flickr account here:
http://www.flickr.com/photos/cameralabs ... 972117933/
As I understand it, you should be able to view all sizes and download the originals if desired, but please let me know if this is not possible.
PostPosted: Sun Aug 23, 2009 1:09 am
I checked their website and it looks like they updated it. =S
and yes, no tamron lenses supported. Only the Sony and Zeiss ones available. I had to manually correct it myself.
Thanks Gordan! It works fine. Can even download the original size..
Tamron 17-50mm F2.8
Sony F58
PostPosted: Sun Aug 23, 2009 7:46 pm
so basically Sony has reinvented the same cameras A200, A300, A350, with a couple of changes: slightly smaller size, a change to SD memory card, and a smaller battery. and they have also eliminated the adjustable color tempature in favour of presets. would have been nice if they had improved it , for example, the ablitly to adjust to 2000 K instead of 2500K.
it seems like Sony is fumbling around trying to find its focus (no pun intended).
have to agree with Gordon: there is no reason/benefit for existing owners of A200, A300 or A350 to upgrade. hope Sony gets it together.
have to stop grumbling now. cheers.
