It is currently Tue Jan 24, 2017 11:35 pm
 Post subject: New Newbe
PostPosted: Sat Apr 03, 2010 11:02 am
Hello all
First I have to say your "DSLR Tips Video Workshops" Gordon are great!!
I have just brought my first DSLR its an Nikon D5000 with lens kit.
I have had old 35mm SLR's before but the new DSLR is a whole new world of learning, But I'm slowly getting my head around it especially after watching the Video Workshops.
I have a question. I took this photo the other day at the top of a lookout and the greens all look yellowish.
What course's this ?
PostPosted: Sat Apr 03, 2010 12:04 pm
Welcome to Camera Labs DND.
Cheers,
onlinedrifter
The only stupid question is the question that is not asked.
PostPosted: Sat Apr 03, 2010 12:54 pm
Welcome to the forums!
Digicams have a tough time cutting through haze. A polarizing filter might help, or you could try setting your whitebalance a bit colder
PostPosted: Sun Apr 04, 2010 7:18 am
Yep, what citruspers said!
PS - Welcome on-board!
PostPosted: Sun Apr 04, 2010 9:14 am
Welcome to the Camera Labs forum!
PostPosted: Mon Apr 05, 2010 12:17 am
I have 5 suggestions:
-Take the photo after it has rained. It "washes" out the sky taking away all that hazy dusty dust.
-Take it early in the morning when air pollution is lower.
-Use an infrared filter. (it will look all weird but it will cut through haze).
-Use a slightly yellow filter if you want to give it more contrast.
-Use a polarizer.
Also: The sky looks a bit overexposed. This might contribute a bit to the haze effect.
PostPosted: Mon Apr 05, 2010 9:27 am
thanks for all the help
what brand of filters should I look for
PostPosted: Mon Apr 05, 2010 9:54 am
I'd say the infrared isn't a real solution to the problem here, and a yellow filter is only for black and white images Agun ;)
I think the polarizer is your best bet here. Hoya makes some good ones, but get the multicoated version if you can afford it.
PostPosted: Mon Apr 05, 2010 10:11 am
Welcome DND! :)
Victor
Website
PostPosted: Tue Apr 06, 2010 11:32 am
thanks Citrusper
is there a certain model number I should look for ?
PostPosted: Tue Apr 06, 2010 2:40 pm
Look for a Circular Polarizer, with multicoating. I wouldn't know model numbers. Also make sure you get the right size for your lens diameter.
PostPosted: Tue Apr 20, 2010 10:45 pm
I think there's also some color cast in addition to the wb and haze thing. I tried some pp on the pic, trying to cut through the haze. I think the end result would have been better and less noisy if the original, large file was worked on. But it does appear pp can't replace a p.filter.
Here are the two images put together for comparison.
